Torque to yield cylinder head bolts
SW Washington
Re: GM 3.4L V-6 with cast iron block and aluminum heads; new Fel-Pro PermaTorque head gasket & new Fel-Pro head bolts.
I had failed head gaskets on both heads of a 1998 Chevy Venture ( #1 & #2 cylinders). Upon installing the back head (the worst one to access) I torqued all 8 bolts to the updated 44 lb-ft and the 95 degree torque angle with the new torque sequence. I believed that I did it correctly but then after lunch just for "fun" I went back over the head bolts with my beam-style torque wrench to confirm that all the bolts didn't turn before the 44 lb-ft. One bolt (lower passenger-side corner of back head; coincidentally the end where the old gasket had failed. This bolt threads into the alignment dowel) turned before the beam torque wrench even got to the 44 lb-ft. I swear I torqued it properly in sequence and although it was a PITA to do, I felt that I also did the 95degrees pretty accurately on this bolt.
Question 1) So why would this one bolt turn at less than the initial torque? Has anyone had this problem before? I understand that these bolts undergo plastic deformation during the 95degree final torque, so given that, I am reluctant to re-tighten this one bolt to the 44 lb-ft and re-do the
95 degrees possibly stripping the bolt or block threads (alignment dowel threads). I am reluctant to buy a new set of bolts and redo the whole head and gasket especially because I believe I did it "by the book" this first time. Perhaps I could just tighten it to 65-75?? lb-ft (the old torque specs on this engines "pre-torque angle" predecessor) or . . . .
Question 2) The bigger question is HOW TO CONFIRM that torque-to-yield bolts are "tight enough"? In the old days of plain torque one could go back over the bolts and make sure they don't turn below the spec torque. But with torque angle--how does one check tightness?
Question 3) I am sure some engineer's handbook somewhere has torque (lb-ft or Nm) to torque angle "conversion" for these bolts with chased, clean, oiled threads, so where is it posted on the internet?
about as tight as you can tighten the bolt by hand with an average 1/2 ratchet is usually about the same as torque + deg. So, if the bolt is turning before 44ft lbs, you ether forgot that one, something is wrong with the threads or bolt, something is posibly in the bolt hole (do not remember if any of those holes had sealed threads, if coolant is in a closed thread area the bolt will not tighten all the way down)
regardless of torque-to-yield or conventional torque head bolts, there are steps/procedures that have to rigidly follows:
(1) find out exactly if the head bolts to be lubricated (lightly) or torqued dry.
(2) make sure that the threads on your block is clean and been chased with thread chaser (repeatedly) until it's absolutely clean. If, for whatever reasons, your block threads are contaminated by motor oil or coolant, make sure you spray them with solvent (after chasing/cleaning) and then blow dry with compressed air before you proceed.
(3) make sure your block and head surface is true. No use trying to install a fresh new head gasket (only to blow it again in very short service time) if either the block or the head is warped.
(4) find out how manufacturers want you to install the head bolts. It's mainly either spiralling from the inner-most bolt outwards, or criss-cross style.
(5) torque your head bolts following the manufacturer's pattern in small incriments. I do so by divvying it up to 1/3: for 75ft/lbs final torque, I do 25ft/lbs first too all the bolts in proper patterns, then 50ft/lbs, then finally, 75ft/lbs.
(6) go back and re-check all torque-to-yield's head bolt torque to be proper before you go through the final step of cranking it per degree angle.
There, you're done.
Q.
Last but not least: for clicker type torque wrench, it's best if you can have them calibrated by a shop or against a known, good beam type torque wrench before you start your head bolt job.
Thanks all. I don't believe I forgot that bolt initially but that is the nature of mistakes. I did have the aluminum heads resurfaced but not the cast iron block. I chased the threads and the bolt screwed in smoothly. I cleaned all the antifreeze out of the blind hole so the hole was clean and dry to full depth, and the bolts were oiled as per instructions on the threads and under the bolt head. GM changed the tightening sequence from spiral to old-style criss-cross & I used the updated sequence. I will probably tighten it down as suggested which would be about 65-70 lb-ft, after all the whole big picture idea is to clamp the head down so that the gasket doesn't leak, and try not to worry too much about it.
Quest, I wish I had done your #6 of rechecking the torque BEFORE the angle tightening; good suggestion.
I had that happen to me on one bolt for whatever reason when I was tightening the cam tower bolts on my GM 2.4L LD9 (the engine is notorious for the bolts coming loose for whatever reason). The spec calls for so much torque plaus another 90 degrees or whatever. I was using a GearWrench electronic torque with angle wrench (recently calibrated from the factory) and all the other bolts torqued fine. I didn't try to rush it and followed the process to a tee but the one gave way. Maybe it was like the one poster mentioned about some [censored] in the threads, etc. Maybe it was a dud bolt. I was lucky I had spares.
The spare torqued fine. (shrugging shoulders)
Can you buy just one bolt?
Then start from scratch on that hole.
We don't know if it is stripped, or you did not tighten it before.
Maybe it's defective and stretched wrong [unlikely].
It's easy to lose track of which bolts were torqued down, especially if you got distracted. Some people use a dab of paint on the head bolt to show that step was done.
That is what I do on any bolt like that. Nice thing about ARP studs is there is no TTY spec, just go in stages using real ft-lb measurements.
If I have to pea ,sneeze, answer a phone call, or whatever, I wait until a torque sequence it done.
I do too.
And even though I do that, I still put ink marks on each bolt to indicate what stage it has been torqued to.
I came back to this project a day later and noticed that all the bolts turned a little at less than the 44 lb-ft (which was the initial torque before the angle torque)so I guess that the bolts "relax" or the gasket compresses over time (?) I guess that GM & Fel-Pro know what they are doing and are aware of such relaxation (or whatever) and that it is all part of their plan (I hope). I will be torquing down the front head soon and you can bet I will double check everything. The front head is so much accessible to work on. I hope for no more blown intake or head gaskets. Thanks everyone.
Something interesting about torquing bolts, ARP wants you to use a stretch gauge on rod bolts. Its pretty much a dial indicator and you tighten the bolt until the desired stretch is reached. It was weird at first, but pretty cool when I used it.
First, thanks everyone. Mechtech I am still trying to wrap my head (pun intended) around bolts as springs but I sort of understand. On second thought I don't believe these bolts are "torque-to-yield" bolts since the factory service manual (which I have) instructs one to clean the bolts as part of the cylinder head remove and replace procedure. If they were torque to yield, which I originally thought they were, they must be replaced as I understand it. So I "untorqued" the rear head and with the help of my 17-year old we painstakenly retorqued it; I feel we did a great job of it this second time. The problem I believe was me not used to using the Lisle Torque Angle Meter #28100 and a difficult to access location--the rear cyl. head under the cowling; I believe the dial was turning some instead of staying fixed the first time I tried angle-torquing the head. The engine was not run so hopefully the head gasket won't mind being untorqued/retorqued. We did the front head easily because it was very accessable. Again, thanks everyone.
Bobo -
If they spec a torque,then a degree'd rotation after that , they are TTL bolts.
Shannow - Yes, SOMETIMES.
I don't like using original tightening procedures with old TTL bolts. Besides, they are not expensive for a whole set, and they are part of a big job.
This is one thing that I don't like to 'cheat' on.
maybe for my own property - a beater.
The diagrams in the linked thread are somewhat exaggerated. Stress in the plastic region is actually flatter and longer in empirical data that I've witnessed. This makes TTY bolts much more reliable for clamp load, and have much more usable strain (or stretch) than the small bit consumed during single use. TTY bolts can be used multiple times until you reach the onset of necking. I'm glad Mercedes worked out the limit of safe use for their bolts.
Once you understand the stress-strain behavior of steel, it makes sense to reuse bolts that are specified for reuse. Others are too squeamish about reusing bolts. For them it's analogous to putting on yesterday's socks. For myself, I saved $60 by reusing the head bolts when I replaced the head gasket 10 years ago on my Mercedes E320.
As I said, Mercedes specifies a max length before reuse. If max length isn't specified, I would recommend using new bolts.
Most of my post was theory. The practical application should be in the service manual and should be followed to prevent waste.
Also, some head bolts can be longer that others, depending on the engine design. It is the long ones that would have more usable stretch.
Those bolts are like springs - measuring torque later is not valid.
+1 one this^
Checking torque on a yielded bolt can over stretch it and cause a failure. I've never re-used yield bolts, better to have new than take a risk. There is no way to "double check" your work. You have to back the bolts off and start from scratch.
With the amount of attempts on your part to double check your work, I'd start fresh with new bolts. I believe that you are going to be at risk for a premature gasket failure due to improper/uneven clamping forces.
