Originally Posted By: kkreit01
Odd -- that your fronts had more wear than rears. My 2wd is the opposite. You must do some hard breaking/cornering, and never spin the rears?
To make things simple, I usually just move Fr Rr (same side). I know this isn't the preferred method, but it's also accepted, and your only option of you have directional tires.
After 18K the rears looked new. I don't think I have ever spun the rears except maybe in the snow. The truck handles real nice once the truck takes a set in the curve. On my daily commmute there are several interesting curves. On FWD cars I have owned I religiously rotated tires, sometimes with good and not so good results. I looked in the owners manual and the preferred pattern on the truck is Frt to Rear not swapping sides.
At 20K the truck tonight got fresh oil and a freebie Fram OCD.
The truck is really breaking in nicely, the steering is spot on, the motor uses no oil, gets real good gas mileage, and performed quite well on a 1500 mile vacation trip carrying my motorcycle and 2 people and luggage. I figure the load was 1200-1300 lbs. Even with this load it averaged 23.5 MPG over 4 tanks of gas. The worst was 22 and the best was 25 MPG. In the future I will probably rotate at about the same frequency, as it will take a while to square off the tires that are on the rear. Sorry to ramble on.
