Allow me to explain the science behind Tire Rack's recommendations.
First, tires will develop irregular wear regardless of which position on the vehicle it is in. But the kind of irregular wear varies by wheel position - especially front to rear. What an owner should want to do is rotate the tires BEFORE the irregular wear gets so bad that it causes a vibration or noise. The key to this is the speed with which the irregular wear appears - which is a function of what the tire is being asked to do (turn the vehicle, accelerate, brake, etc.) and the alignment in that position. I should also mention load and inflation pressure.
Tread wear is not even throughout the life of a tire. It is faster when the tire is unworn and slower as it approaches wearout. That's because the height of the tread blocks is taller (and therefore more flexible) when new. Further, some tires have shallow sipes and angled sides to their grooves, thereby changing the geometry of an individual tread block and the rate the tread wears. If you were to accurately and frequently measure the tread wear during a tires life, you would see a curve.
Rotating tires puts a different wear pattern into the tires, thereby slowing down the rate irregular wear is forming.
But since tires wear faster at the beginning, it would be advantageous to have the first rotation a bit early.
