Env1ous
Originally Posted by geeman789
Originally Posted by Env1ous
Don't want a soft ride. But when I hit bumps my rear kicks out on me. So I was more so wondering if I had them over inflated and I do. So it does hit bumps a little stiffer than it should
ALL unloaded trucks do THAT ... ! Put 1000 lbs in the back ... that will fix it ! Or run the rear tires at even lower pressures ... when EMPTY.
I have had 4 trucks and probably put about 100k miles on them. It is the tires. I had E rated duratracs, BFG KO2s, and some P rated tires. The Ps were a better ride but did not last lol
Got way too many flats. These are the only tires that kick out on me like this. I think they are a lot more sensitive to PSI than all the other brands because I had the same PSI in the KO2s and the duratracs.
