We have a Craftsman 26" rototiller (bought new in 1997, I think, so it's about 14 years old) with a 5 HP Briggs and Stratton horizontal shaft engine that would not start a couple of days ago. This thing has a manual choke. Pulled and pulled and pulled, and still no start. I tried all different choke settings, and it would not kick. So I removed the spark plug and noted that it was dry, with the plug itself looking good, very little wear on the electrodes. So I poured in a small amount of gas into the spark plug hole, replaced the plug, pulled a couple of times and then it kicked for a second or so. OK, so it's obviously not getting gas into the cylinder, which probably means a carburetor problem. So I removed the air filter and sprayed some Amsoil Power Foam carb cleaner into the throat. Pulled again. Again it kicks but no start. I figured the carb was bad, so I decided to leave it and started looking online for a new carb.
Fast forward to the next day. I decided to go out and give the tiller another whirl. Guess what? It fired right up! Obviously the carb cleaner I put in there soaked for a while and cleaned out the carb overnight! So if you have a no start condition caused by a faulty carburetor, give it a few shots of carb cleaner (and Amsoil Power Foam is a good one), pull the starter cord a few times to suck it through, and let it sit overnight if it doesn't start. Then try again the next day and it just might fire up for you!
I always use some kind of fuel stabilizer with all the gas I put in my small engine equipment, but the tiller apparently does not get enough use to keep the gas fresh even with stabilizer. I guess I'll start siphoning out the gas and running it dry if it is not going to be used for a long while.
