- Joined
- Nov 29, 2009
- Messages
- 9,568
I finally found some made by permatex It's aviation grade. Part# 80019. Anyways, I've read how you aren't supposed to use Teflon tape on npt fittings for gasoline. I think because a small peice can get into the fuel system, but how does this pasty permatex stuff not get into the system? I mean wrapping with Teflon tape isn't hard to keep a couple threads from the end. Also what about if you need to take a fitting off? How do you clean liquid sealant off?
