I pulled apart these hubs for maintenance and this is what I found. Tandem axle boat trailer, new bearings 6 years ago, Lucas marine grease, brakes on all hubs. Probably only have 2000 highway miles total as it didn’t get used much those years. In and out of water maybe 3 times each year.
All 4 hubs were similar grease around the bearings was dark and discolored but still thick and greasy, did not feel broken down. Any grease in the middle of the hub or cap away from bearings still had original Blue color. Nothing seemed necessarily alarming and all bearings looked good and shiny except this one. Had a colored streak on the rollers but the race was fine. The 2 bearings side by side for comparison. I’m putting all new bearings in any way but I wouldn’t be scared to repack and run the rest of then, even this one is smooth just discolored. I temp check on long runs and never see more than about 140 on a 95 degree day and using brakes to stop, and they have never been out of adjustment.
Is this a grease issue, contaminant issue, or material issue?
