Thought This May Interest BITOG Members
Northeast Georgia
Obtained this directly from the Kinder-Morgan facility where we load fuel. Techron additive injection rate as it gets loaded...
[Linked Image]
Originally Posted by CT8
Premium has less Techron?
More Techron for Premium per given quantity.
Example:
Reg/Mid 4951 - 5500 gallons gets 10 quarts Techron
Prem 4951 - 5400 gallons gets 12 quarts Techron
More. The rate is adding the same amount to fewer gallons of gas, so the result is a higher concentration.
So is this the same Techron you buy off the shelf, or is it a more concentrated solution? Is this to reach EPA minimum or is this the blend rate for Chevron top tier fuel?
The stations in my area have only a regular and a premium storage tank. Their mid-grade fuels are drawn from each tank to give the mid-grade octane.
It's odd that this paper shows a mix ratio for each different grade. I suppose in other areas of the country the fuel is distributed differently.
I would assume that they (Kinder-Morgan) are delivering the gasoline to various gas station brands?
Does this mean that they all use Chevron (techron) additive regardless of brand?
Come on CT8
I'm gonna get you a specialty trained dog that will bark at the product with the higher concentration...
Rex the specialist math trained dog will help you out big-time
Since no alcohol premium costs me $.80 more, they should include more additives. Glad is only for motorcycle and lawn equip.
Rod
What makes it odd? It works as designed. Obviously a lower mix rate regular is mixed with a higher mix rate of premium to produce mid-grade. The final additive mix rate of the mid-grade would automatically fall somewhere in the middle...same as the octane rating.
This sheet is ONLY for Chevron gasoline.
Originally Posted by ctechbob
A little goes a long way!
Read where the rebadged outboard motor companies sell a stronger Techron than say, AZ has for cars …
But always figured I'd just overdose my boats gas since I only buy it on sale anyway …
It has to be a commercial grade concentrate. No way they're telling consumers to add 1oz per gallon, but then dosing a station's tank at a minimum concentration of .06oz (rounded) per gallon. You're talking roughly 16 times less concentration at the pump as compared to using a bottle off the shelf as advertised.
If this truly is the case, then they're not kidding when they call the off the shelf product Techron Concentrate.
Example:
Thanks I am bass akwards.
Come on CT8
I like dogs and need a special dog.
Come on CT8
I like dogs and need a special dog. Dalmatian maybe ?
Absolutely !!!
Dalmatian he will be... And helpful too
Hope you are doing good... Good to see you on here.
That's good to know.
Years ago I remember Exxon being delivered in an Exxon truck....Shell in a Shell truck....Sunoco in a Sunoco truck etc....nowadays they all seem to be delivered in
the same trucks....It's made me wonder are they all selling the same gas?
