92 Camry V6, 162,000 miles. Amsoil 10W30 since new changed every 7500 miles. Now uses about a quart during the 7500 mile OCI. Currently doing an RX treatment for seepages.
I think I can safely say that guy got his money's worth. That is just awesome!!quote:
Originally posted by Patman:
The LS1 is proving itself to be a durable engine, even with it's piston slap and consumption issues.quote:
Originally posted by Last_Z:
I'll be happy if I can get 100-120k miles from my LS1......I don't see why it couldn't.
Rick
There is a guy on Corvette Forum who at last count was at 317,000 miles on his 99 Corvette. He has done 5000 mile changes with Mobil 1 5w30 (probably could've doubled those change intervals and still been safe though since he does all highway driving) It's his daily driver, he is a salesman who travels all over Michigan. He just slaps on a set of Goodyear runflat snow tires for the winter season and keeps on truckin!![]()
You are a good man Terry!!quote:
Originally posted by Terry:
No heater fan, radio, air conditioning.......I believe in torturing my kids to center them for the real world![]()
184,xxx here, a few minor leaks here and there but otherwise no problems. Doesn't burn any oil and still has 25-30psi of oil pressure at idle when hot. I've had the intake and valve covers off a few times and the motor looks very clean inside. A bit of varnish buildup but zero sludge.
I almost always use Mobil 1 10w30 with a AC Delco PF35 or 1218 filter on a 5,000 mile interval. When money was tight I did use Castrol GTX a few times. I bought the car with 118k on it so I have no idea what kind of oil the previous owner used.
__________________
Jason
93 TA, M6
Originally posted by Curtis Newton:
[QB] 1988 Toyota Camry, 4 cylinder with automatic transmission. Original transmission/engine. As of two weeks ago, ~299,600 miles.
R:
Man, I love you getting the miles you do out of an AUTOmatic. Could you explain if its due to treatments or fluid changes or cooler?
The car has had treatments of Slick50 at 90,000 miles, 150,000 miles and again at 220,000 miles.
R:
Man, I like that TEFLON and it held... makes me feel better about my teflon run.
I run a little Taco -ma, and it sees a lot of courrier work. It's a 1997 2.4l Standard Reg. Cab, base as you can get truck. Got it with about 148 miles on the truck from the StealerShip enterprise Toyota Stealer here in Houston, Tex.
They wanted to get rind of the truck because it was a DEMO, and the salesman said people don't like to buy new cars with over 100 miles... And they actually gave me the truck for less money than we agreed to.
This little Toyota had always burned oil since new. It sucked down 5w30 which when I got the truck was almost a feat in of itself to find, even the StealerShip selling the truck did not carry it nor offered it THERE as a FILL. So I went to DINO 10w30.
Tried many different dinos, mainly to reduce the burning at first. But ALL were BAD... so I just kept extending drains and went to a straight 30w.
The 30w cut my brun to a level I felt was okay and then I changed brands to a premium oil after I was sure the burn was reduced.
Stuck with DINO the whole time. Played around and instead of bumping to a 15w40 (maybe later) I went with a 30w + VII, and that almost stopped all burn whatsoever. Then I bumped up my drains into the extended range, ---->extended, then I'm at where I am now at 398,212 miles with the cover open for a seal job and the pan off for a leak, several other things like a rear seal every 100-150K and fron crank seal leak just recently, a lot of leaks in this beast.
Recently I went to some DINO with no moly in it and as some know I am doing a Teflon test, and about more than midway past that, then I will do a couple tests with Moly again (gonna stick with moly) and I have to use up about 72 Quarts of a 10w30 dino with moly before I can go (or will most likely) back to the 30W straight and finish that off, then, unless LIFE happens, I will consider and likely move to 15W40 because I'll have aroung 600K++ unless severe leaks happen again, and see how it does then... Tried it recently on a short drain (22 miles I think) and it was too sluggish, need more wear)and if everything holds up, and it is too sluggish at 600K I'll wait to 800K to move up to a 15w40 DINO, unless technology improves, and then I may go with a Syn by then, you never know!
