I've been growing some [censored] pear cactus in my front yard, in anticipation of going to a gravel/cactus theme, which seems appropriate for a place with almost no water. One very promising plant, which sprang up pretty quickly, developed some white puffy patches, which I assumed were a fungus. These deposits spread, and the plant died. Recently, the largest cactus that I have so far grown from a cutting began developing these same spots. I really didn't want to lose this one, so I Googled "cactus fungus" in hopes of finding a solution. Boy, did I!
It turns out that the cochineal insect will attach itself to a [censored] pear cactus, and insert its proboscis into the plant and live out its life there, drawing sustenance from the cactus. It's the female that does this, the males are smaller, and mostly mate and die. The female will deliver a number of nymphs that are carried on the wind to hopefully find other hosts. Based on what I've seen, they will also sometimes colonize the same cactus that the mother is on. Enough of them on one plant can kill it. That explains a lot, given my experience.
Turns out, you can just scrape them off, along with their waxy deposits. It's recommended to also use insecticidal soap, which I will have to pick up.
The cochineal insect is also used to make cochineal dye, which is still a very popular scarlet dye.
I'm just glad that I don't have some sort of deadly cactus fungus lurking in my soil.
