That sounds like my setup. I run the Eao-26 spin on filter, and the EaBP-90 for the Bypass filter. I highly recommend adding a petcock to your bypass setup , it makes sampling a breeze.
Originally Posted By: Pablo
Originally Posted By: StevieC
Pablo is a good guy for sure. I wish I lived in the U.S. and could support him with my Amsoil purchases.
Thank you sir. Just for the record, I can still be your dealer in Canada.
Ok then, as soon as my membership expires under the current guy I can't seem to get a hold of I will re-setup under you.
UOA I did last year. (Sampled, not changed) Just wanted to add this here. Will add another one just before installing the bypass system but just to give you an idea of how the engine is on oil without bypass.
Shortly after this report the temperature sensor and thermostat failed. It's why KF Water test is a bit high and same with Nitration these should be closer to 0 in this engine but because it was running rich these were affected.
Before I install the bypass system I think I'm going to fill the engine with fresh 5w20 SSO and drive it around the block and empty it out. Then install the system with 2 new filters and fresh oil so that it's as clean as possible before starting the bypass filtration.
I will of course saved the drained SSO and use it in one of my dad's beaters.
