Tape measure that isn't like a wet noodle?
Northeast
Any recommendations for a good tape measure that will stay straight when it's extended, and doesn't bend as easily? I admit I usually use cheap tape measures, and that's likely the problem.. But I'm just curious to see if anyone has recommendations for a solid tape measure. Maybe I should just get a laser type tape measure instead..
Fatmax or Dewalt, both have the same blade. I've had Stanley tapes my entire life so I really hate the Milwaukee but people buy them because they are cheap.
16' of course, compact and long enough 98% of the time. Definitely get the laser rangefinder, they are the most accurate method for internal measurements. I lost mine and miss it but I'm too cheap to buy another.
I have a 35' stainley. lol Works fine. Just as long as it's the 1'' wide style tape, it shouldn't be like a wet noodle.
Thanks for the replies so far everyone. Good point on the width, I never thought of that. I was just thinking of the thickness of the metal, but it makes sense that the width would play an important role as well.
I have quite a few Stanley tape measures....All being at least 15 years or more old. The 35" Classic Chrome & Contractor Grade are my favorites & are almost identical to each other.
Stanley , craftsman , or the new Bauer tape measure at harbor fright
I have a 25' Pittsburg Harbor Freight special that I got, "free with any purchase". It has turned out to be the most rigid one I own, as far as extending it before it collapses. Usually the wider the tape, the better it holds up when extended long distances.
1) Wider Blade - will not flex as much (as others have said) / try them in the Store before buying.
2) Good Lock to hold Blade extended
3) I get by with a 25' around the house / 8' kept in vehicle to use at Hardware Stores
4) Good Graduations - make sure you like the graduations on 'both' sides of blade.
Some manufactures will have 1/4, 1/2, 3/4, etc and it clutters up the scale.
Tape Measure Trivea:
Question - Why does the metal Hook on end have a little side play ?
Answer - To compensate for the thickness of metal Hook if your measuring 'inside' of something.
Cluttered:
[Linked Image]
I like:
[Linked Image]
Originally Posted by SeaJay
Or tape a few wooden yardsticks together
Already invented.
My Father had one of these / I don't, for obvious reasons.
[Linked Image]
Already invented.
[Linked Image]
For short distances these are nice to have, I used them when I was a mason, just have to be careful not to pinch your fingers.
