Androbot,
You are sounding like a broken Amsoil add (no offense Pablo). I know you are enthused about synthetic oils from your postings, that's fine. Just don't assume that they are the better choice for most applications..
No one BUT YOU mentioned 2-3k mile OCI's which are not even recomended by any OEM other than a few that lag behind.
It is not a myth that vehicle manufacturs and dealers will scrutinize your maintenance records should you ever (albiet rarely ) have a failure. Neither do I argue that using synthetic oil in a new vehicle for longe OCI's is a bad Idea , indeed it is a good idea if the owner is driving 15k or more a year where long OCI's can be a time and resource saver for a person with a busy lifestyle.
However, for a person with a short mileage regimen in a non-high performance application or not living in a subzero temperature environment there is no convinceing reason to go with a synthetic engine oil other than owner placebo effect.
Americans in general, are easily marketed up market because they have been conditioned to believe that if they spend more $$ they are getting a better product. I do not believe that #@$%!, I believe the hard data and the many high mileage vehicles that have made it there using conventional oils.
