well , when I did use regular oil to about 74,000 miles on our 2000 PRIZM ( Corolla ) the temp gauge read at exactly 1/2 , then when switched to 5w30 M1 synthetic the gauge lowered by about 2-3/16 ths of an inch . Then following oil change went w/ PENNZOIL PLATINUM 5w30 and the temp gauge remained the same . So , was told could be thermostat , went to TOYO service center and had anti-freeze changed ( figure time for new anyways ) and replaced old thermostat w/ TOYOTA thermostat . Guess what , the temperature gauge remains the same . Therefore , has to be the synthetic helping to keep block cooler . Last , was over 90 degrees and humid , so had to use the A.C. and the gauge never budged , before w/ the dino on day like today the gauge would sometimes rise about 1-2 sixteenths of an inch . This included plenty of city driving and 70-72 m.p.h. on the highway ( w/ AC on at times when climbing long steep hills , putting her to the test , w/ plenty of power to boot )
. Only downside is the valve cover gasket could be seeping since the switch ( cleaned around it , keep an eye on it )
. Let the debate begin .
