Originally Posted By: Trav
With 1000 ppm phosphorus and 1100 ppm zinc Mobil 1 0w40 is high on the zinc scale for a pcmo and should be enough for a flat tappet without any additional zinc additive.
I thought that API SN puts a limit the zinc contents to 800ppm?
Originally Posted By: Astro14
I think your Chevy will be just fine on 0W40.
Sweet car by the way! Love the '65 with its round tail lights. My cousin had a '65 rag top. It was no collector car, and slow with that two speed powerglide, but such lines....
200k miles on dino sounds good. I’ve been told that the SBC will only last about 100-150k on regular oil. Complete bull I guess…
I know, I like it alot.
The powerglide in mine is a constant discussion piece whenever someone rides with me. For some reason, a two speed transmission is something spectacular for most people. I’ll guess it’s because most people ‘drive’ around with 8-speed autos and 6-speed manuals these days.
Originally Posted By: bubbatime
Can you get 15w40 dual rated diesel/gas oil? It is IDEAL for that old car.
I wouldn't run synthetic in such an old car. 50 year old oil seals and synthetic are not a match made in heaven. Plus it's been on dino it's entire life most likely.
Yes, 15w40 is readily available. I’ve been told numerous time that I should not run synthetics in vehicles that has been fed dino for its entire life. Even though I believe it holds some merits, I still think it’s better to switch to synthetic than to keep running dino until the engine dies. Seal condition additives are part of most oils these days, and if it starts to leak it was due anyway.
Originally Posted By: Nickdfresh
Can you get (Euro) Valvoline MaxLife High Mileage 5W-40? It would be perfect for this application IMHO...
Yes, it’s available for about 13$ / quart. What kind of synthetic is that, group III?
Originally Posted By: bullwinkle
I had a '65 Impala SS 283 (2 barrel carb) back in the day-there's not a lot of valve lift or spring pressure on those old (non high performance) SB Chevy V8s-the M1 0W40 you're running is a lot better than the VI-laden 10W40 dino oil I ran then. Or, if it gets too cold, a dual rated 10W30 HDEO would be a good choice too (not sure of the ACEA spec).
10W-40 is kinda of a funny grade. Nobody seems to be using it over here. Maybe because its bad reputation of being prone to breaking down due to its high VI content? 10w30 sounds like an oil that would be to thin during heat soaked days. Or am I to brainwashed into the whole “the thicker, the better” scheme?
Originally Posted By: Alex_V
15w40 is too thick unless you're frequently working it hard in fairly high temperatures. I'd be using a 10w30 in it, but the 0w40 probably performs similarly enough to do just as well. A dual rated 5w40 wouldn't be bad, either - I'd probably opt for that over the 0w40 for any increased extra extreme pressure additives it may have. However, I'm not of the belief that any flat tappet engine needs loads of extra ZDDP just to get by.
Sounds like a cool car. Pics and options?
Can the Valvoline MaxLife 5W-40 be considered a dual rated oil?
ACEA: A3/B3, A3/B4
API: SN/CF
283 2-bbl powerglide. 4-door HT. Not much when it comes to options... got neither a tach nor a oil pressure gauge. AM radio, which is useless here (no AM radio stations here). No A/C. It doesn't even have a fan shroud
Originally Posted By: theeagleflies
IMHO and not overthinking the application; consider a high mileage oil type, either semi synthetic or dino 5w40. would avoid M1 products for that era motor. change 1 year or less or 5k miles or less. just my experience and opinion taken away from it.
Any particular reason why I should stay away from M1?
Originally Posted By: BrocLuno
All this talk and we don't know how many miles are on the engine ...
Roughly 80k on the odo. Unknown maintenance up to about 70k.
The seals are old and pre-synthetic chemistry. The valve seals are as hard as rock and cracked, or missing. The generator is nearly toast (hanging off the exhaust manifold (?). The fuel pump is a big worry. As soon as it perforates the diaphragm it will be pumping gasoline into the crankcase. The oil filter base is sludged-up to beat the band (canister filter unless it's been modd'd to spin-on...). The oil screen pick-up is also half clogged ... And the cam is already gone halfway flat.
Things that need doing. Timing chain replacement. It is semi-dry and stretched and running with the cam at least 3* retarded ... You can change the timing chain from the front/top. If it's all dark and crusty, you need to think about when you'll replace/rebuild the motor? You can get another 30,000 miles with a new timing chain, but ...
Start looking for a good used 327 rebuild-able core.
Aren’t you a glass half-full kinda guy?
Originally Posted By: Dallas69
Just run a 10-40 or 10-30 Maxlife if you can get it. Any major brand will work. I would not use a 0w oil unless you are in very cold temps. I am not a fan of Ow oils.
Any particular reason to avoid 0W and run 10W-40 instead? I’m not a fan of 10W-40, as they seem to be dino based with a lot of VI in them.
ACEA: A3/B3, A3/B4
API: SN/CF
