Switching back and forth between oils
North Texas
Is it typical bad to do this? I’m doing this on my 24 Tundra. Currently running M1 EP and MOA for 5K intervals. I’m having the dealer do the 10K with I’m just assuming bulk oil. I prepaid for maintenance up to 85K but don’t want to wait 10K to have the oil changed. Plus this give me a chance to look things over. Thanks.
  • Like
Reactions: wlk
I'm retentive, so I could never do it. I'm planning out a potential switch from Amsoil SS to HPL PPPCMO, but because I have a case of Amsoil on the shelf, not for another two OCIs. I just changed the oil the other day, so with our usual annual mileage, it will be toward the end of next year, or maybe into 2027, before I'd make the switch. I've already researched HPL's recommendations on shelf life of their oils as well as the shelf life of Amsoil's EA15K13 filters (five years per their tech support line :rolleyes: ). Looking forward to HPL's 4th-of-July sale to see if I'm going to buy and switch.
I wish my brain was wired to not worry about little stuff like type of oil in my engine, as long as it meets manufacturer's spec and is changed regularly.
There's a thread talking about when Amsoil is going to refresh their Signature Series line, specifically 0w-20. If and when this happens, do they keep the current and offer the new? Or just change the formulation and not say anything because they know changing to the new isn't relevant?
Coke? New Coke? Classic Coke? They shouldn't have came out with the New Coke marketing campaigns. Unless someone other than Coke had been doing Virgin Coke Analysis (VCA) on a consistent basis, the world would never have known, and Coke could have said "Hmmm, that's odd. We'll look into it".
I don't want to think about UCAs.
There is a risk of additive clash between oils of differing chemistry. This is a small risk, unlikely to occur and unlikely to cause a significant issue (relative to engine life) if it does, but a risk nonetheless. Any harm from frequently switching brands is unlikely, but it is always optimum to continue using the same brand.
Once upon a time…..it’s mostly people latching on to things with a little truth behind them and letting their imaginations run wild.
If you want to go out of your way and mix a high zinc and a high calcium oil together, you could manufacture problems.
There’s a certain cognitive dissonance in all this. If you’re willing to put third party additives in your oil, how legitimate is the concern about third party additives from residual oil?
Excellent point. Deliberately changing the chemistry of the oil with an additive while worrying about the chemistry changes from swapping is not logically consistent.
It's fine I have swapped for 30plus years back and forth between whatever I have bought or in my stash of oils. The trace amount left behind is not going to hurt anything.
Why mess up a perfectly fine oil with an additive?
I completely read over the part about MOA. There's nothing in that supplement that will improve M1. It's just making your wallet lighter. Ditch it.
Other than some folks here , who says this is true ? Any documented tests ?
I have been operating under the presumption that using only exactly one oil...brand, formula, grade, has cumulative positive benefits.
