I changed the ATF then drove it about 25 miles the next day and it stalled three times and the wrench symbol showed up on the dashNot very, as in, like never?
I wonder if something got unplugged--was this a job you did, or someone else? Stuff happens. Heck it may be completely unrelated, if the vehicle is old enough.
Wrench? guess I'm used to it looking like an engine.I changed the ATF then drove it about 25 miles the next day and it stalled three times and the wrench symbol showed up on the dash
I did when I changed it . The drain pan showed I drained out 5 qts and that's what I put back in . I also checked the dipstick .Have you double checked the ATF level correctly?
Wrench icon is usually a maintenance reminder. Ford "wrench" denotes a power train issue.How common is it to have a vehicle stall out after an ATF change ?
Ford EdgeWrench icon is usually a maintenance reminder. Ford "wrench" denotes a power train issue.
Make, model and year?
What replacement type of ATF was used?
That’s a long shot...but perhaps.Follow Up : I still dont know the cause of the stalling but I drove it the next day and up until today it hasn't stalled out . I'm guessing there's a ATF sensor that wasn't giving an accurate reading and would cause the vehicle to stall to protect the Transmission .
Which Valvoline ATF?Ford Edge
Valvoline ATF ... Blue Bottle
First thought to me is a ruined transmission by using the wrong fluid, one place not to experiment with transmission fluids, unless you are a transmission tech that likes to remove them and work on em. Always use what the manual says to use, or else!
Model year?Ford Edge
