How would you rate Supertech dexron III?
It was on the cheap at Walmart, I am short on funds and need to do a pan drop on my 4T60-E. Don't know if it matters but I doubt if the fluid in there has been changed more than once. However, it's been leaking steadily from the pan gasket so what is in there is pretty fresh
the fluid on the dipstick looks good but the leaking gasket is the root problem so I'm going to change the filter while I'm in there.
I've used Supertech motor oil many times before and it seemed fine to me.
Secondly, are any trans fluid additives recommended? For higher mileage units in particular, this one has 160k miles on it
