My wife's '01 Dodge Grand Caravan 3.8L AWD 87K miles has had a major squeal upon morning startup in the 30-40F degree garage. It would go away after 1-3 minutes depending on the temperature. After it was warm the PS moaned during turning at low speeds.
I was all ready to replace the PS pump b/c when I put a wooden dowel to it during the cold starts, I could hear what sounded like a bearing.
I looked at alldata.com and found the TSB for the PS. I had the dealer print it for me. It said to replace the PS reservoir and put ATF+4 in it.
The reservoir was only $16 and I did 4 suctions and replacements after turning the wheels (off the ground) several times.
The moan is gone and best of all the morning cold start squeal is gone!
The $21 for the part and fluid sure beat a $250 dealer PS pump replacement ($100 part and $150 labor).
I am amazed that the wrong fluid would make that loud of a racket. I thought for sure it was mechanical.
I am going to drive it a week and suck out the reservoir and replace. I'll do that 3-4 more times. I read about people doing flushes like a transmission flush, but the suction is easy.
I used a Napa suction gun that I got for $11.
