Small Briggs & Straton 4.5 Push Mower
Thomasville, GA
Hey Guys,
I don't check the oil in my push mower enough, I know tisk tisk. I guess since it is a little $100 "Weed Eater" from Wally World so I tend to ignore the maint.
Anyways, I checked the oil today before mowing. The good thing is, it has oil, but it doesn't even look like oil, hah. It is black to say the least.
How can I look up how much oil the mower holds? Also, what should I use in it.
I have the following laying around, can I use any of it?
2 Quarts of Synthetic SuperTech 10-30 (What I use in my riding mower)
1 Quart of Synthetic Amsoil 10-30
1 Quart of Mobil1 10-30
Please keep in mind, I no longer use synthetic in my autos that I have now. I may switch my wife's vehicle that she just bought, but to neither of those brands probably. So I have no use for them, might as well get some kind of use out of em.
Thanks
Well, 10w30 is the proper weight for your mower, so you've got that covered lol
Just choose one and use it. Most of those small engines take about 16 oz or so. Some have a dipstick and some you just fill til it runs out at level.
With a Briggs & Straton I think it calls for SAE 30 or Synthetic 5w30 but any of those Synthetic that you have listed would do just fine.
Andy
i have always used straight 30 in all my yard machines even my 1966 Allis Charmers Briggs and stratton snow blower which still starts and runs great..The only part i replaced was the ignition it had breaker points but they disintegrated and i converted it to electronic ignition..
Yes, you can use any of that oil. I usually prefer 30WT Rotella or similar in my small engines. I had a bottle of Pennzoil High Mileage 10w30 laying around that I used half of in a co-worker's mower this week. Pretty much any xW-30 or xW-40 will work fine. I used to run the 0w30 German Castrol in the Hondas. I don't remember why I quit using it. Probably because I had so much other oil laying around; I quit buying individual quarts for the mowers.
Yup...read the book. It will almost always tell you straight 30 weight. Exceptions would be that Hondas say 10w30...so do many engines on John Deer power products.
I use about 60 or so quarts of straight 30wt HD each summer on mowers. Sometimes 10w30 is sale, but I don't buy it.
Being a dumb hillbilly and all, can someone tell me the big difference between straight 30 wt and 10w30. I know, I just fell off the turnip truck! I don't want to mess up my customers mowers, and while I'm pseudo engine smart, I'm definitely oil dumb.
10w30 is required on all kohler ohv engines. All briggs and kawasakis require sae 30, multi viscosity oils are mentioned based on temperature, but we are talking about a mower, so sae30
From what I've read, multi grade oil will not hold it's viscosity indexing as well as a single grade oil. Straight 30 weight is recommended as optimum but multi grade oils are also included on the list of engine lubricants.
Personally, I don't sweat whether it's 30, 10W30 or 10W40 as long as it's a good brand name and the oil is reasonably priced. If I see Shell Formula 10W40 for selling for $1.79 beside Shell 30 selling for $3.99, well, that's pretty much a no brainer. I'll scoop up a bunch of the 10W40.
These engines need fresh oil at regular OCIs. It's been my experience that the engine really doesn't respond any differently regardless which oil I use provided it's within the designated viscosity range. I have engines with many, many hours on them, still running strong by using decent oils of varying weights and brands. It really doesn't matter. Regular oil changes with proper viscosity is what counts.
http://www.briggsandstratton.com/maint_repair/routine_maintenance/changing_oil/
SAE 30 and SAE 10w30 - you're good to go whether they are conventional or synthetic.
Synthetic 5w30 is also good to go between -20F and 120F.
