On the day I joined the forum BITOGers nailed the culprit of my sledged up Corolla to a faulty PCV valve. There were some requests for pics, here's what I have so far:
http://www.flickr.com/photos/spyder73/4897323519/
First pic was taken on July 23/10 and shows the sludge build up when I first really noticed it. Its not the highest quality shot (limits of my cell phone camera used), but you can make out the baked on sludge through the oil fill hole. Harder to see in this pic are the clumps on the fill cap.
http://www.flickr.com/photos/spyder73/4897323627/
Second pic was taken July 30/10. Joined BITOG on the 28th, ordered the replacement OEM valve on the 29th, and I installed it when it arrived the next day. You can see how gummed up the 10 year old factory valve is. OEM replacement is still in its baggy behind it, fresh from the local Toyota dealer.
http://www.flickr.com/photos/spyder73/4897342957/
Same thing but a better angle.
That's the photo backdrop to the project. I'm about 2,000 km into the same oil that was put in shortly before the first pic was taken (Toyota 5W30). About 1,500 km on the filter (M1 EP).
I still have the filter that was removed only a few days before that first pic was taken. I plan to cut it open and add pics of it, along with (hopefully) a better "through the hole" crankcase shot, which shows some cleanup since that first pic was taken and the PCV valve replaced.
This project is still ongoing, so I'll update when there's more to add.
-Spyder
-Spyder
