Donald
Originally Posted By: LeakySeals
I had a 98 GC with same issues. The combo of tall with a narrow wheel base had me wandering and leaning from day 1. Tire selection made a big difference. Ended up with larger rims/smaller sidewalls. best I could ever get it. Have a 2011 GC much wider, doesn't do it at all.
I understand, but this has gotten worse over the past few months. Especially when one side hits some rough pavement and the other side is OK. Around here for shoulder stability they often pave (over old pavement) the outside 4' or 5' and not the entire roadway.
Yeah I think your year still had the independent coil spring suspension. Great for climbing boulders and off roading, but acts strangely on mixed pavement. Got worse as it got older. Stiffer shocks help some, but will still lean over on the coil springs. A smaller sidewall by an inch may help prevent some of the sidewall roll. Also the quadra trac went, after replacement that clearly helped. It was surging some wheels more than others. Not sure if you have that.
I have SelecTrac. But something has indeed gotten worse over the past few months, tires were not replaced during that timeframe. It was not this bad when I bought it with 57K on it.
