Should I change my oil?
Michigan
Last weekend I went to a buddy's house to put long tube headers and motor mounts in my Camaro. On the way home the car was running kinda rough, so I looked under the hood, and I discovered a coilpack was unplugged during the entire 30 mile drive home.
Should I be concerned about fuel dilution from fuel sneaking past the piston rings on that cylinder?
I used Redline 5w30 before I put it in storage, and have only put about 75 miles on the oil. I'd rather not dump it if I don't have to!
With 30 miles of fuel wash, I would at least do a compression test on the effected cylinders.
Thanks guys, I guess I won't worry about it then.
Originally Posted By: Bud_One
I'd be more worried if I had killed a catalytic converter or not.
No need to worry. I'm 100% certain that no catalytic converters were harmed by this.
