Originally Posted by Pelican
Originally Posted by SlavaB
Hey folks!
Question about my 2015 MB GLA250.
It has only 23k miles, yet it's 4 years old now and my wife takes lots of short trips.
The battery shows no signs of going bad, at the same time it was like that for my Kia as well and then it just wouldn't start one morning.
Should I invest early into the new battery?
There're 2 nice deals going on right now:
1. Champion AGM $160 + tax (including $18 core charge refundable)
https://www.pepboys.com/champion-agm-battery/product/2071686
2. Autocraft Platinum AGM $168 + tax ($22 core charge refundable) (which seems to be rebranded german Varta)
https://shop.advanceautoparts.com/p...-group-size-h6-760-cca-h6-agm/10210829-P
My 2008 MB E350's battery lasted 4 yrs under the same conditions. If yours is a AGM it will not give you any warning, it will just fail.
I would only use an OEM battery, I think Varta is still the supplier, they are more expensive, but you get what you pay for, 2nd choice would be Odyssey or NorthStar (same company also expensive) 3rd choice EastPenn/Deka. Don't wait till it fails as it will affect many other features of the vehicle.
Hey, that's the same car I have, you're in a colder location too so don't know what happened. Mine is 11+ years old so it's just one of those things. I wonder what your voltage was. You can get to the voltage display on the E350 by switching to the temperature display with the engine off and hitting the reset button 3 times. Varta is Johnson controls.
Also if OP decides to get the battery, Pepboys has a $40 rebate on the Champion AGM battery til March 31st, but they've extended that rebate a couple times since December. Champion is also JCI along with Autocraft so get whatever is cheaper. Advance auto typically has a 25% off discount code on retailmenot.com. Autozone is usually just 20% off and their pricing is similiar to Avance auto so Advance Auto is usually a little cheaper.
https://pepboysrebates.rewardpromo.com/#/home/current-offers
The correct response is to get it load tested. Otherwise you're just replacing something that isn't bad. Load testing is free at auto parts stores. AGM is supposed to last longer than flooded but as you can see, it can vary.
