Sears lawn mower / Tecumseh engine
Ottawa, Ont CANADA
I am in the process of doing the light spring maintenance on my dads Sears lawn mower (crica 1961). I have about 1/2 litre+ of M1 15w50 tri-synth left. Do you think it would it be OK if I were to use this M1 oil and top up with a lighter weight ? Or would that be just a plain bad idea.
Thanks
Jean
Use the mobil in the lawn mower the 15w50 will work great. The oil won't cause any seal problems.
[ March 24, 2003, 05:53 PM: Message edited by: Steve S ]
My dad has almost the same model.
He has an Eager-1 (silver chassis w/ Red engine panels). He uses SAE 10W-30. Tee manual states to use SAE 30 or 10W-30.
I tell him to use Pennzoil API SL 10W-30, cause it has moly and its low temp viscosity will allow it to lube the engine fairly quickly in a cold start.
My motor is the same I have used 15w50 Mobil1 Amsoil 10w30 Delo15w40 they all work fine .The lawn mower part will rot away before the engine wears out. Like my last one did .
