Originally Posted By: dubber09
Originally Posted By: Mainia
Originally Posted By: ChrisD46
Te above reflects what is shown in my maintenance manual: New Hyundai has no ATF dipstick , basically a sealed unit which Hyundai states does not require service . **I am very skeptical about such a statement or a supposed sealed AT which is "maintenance free". The Hyundai Sonata AT has a drain plug and a bubble level port for ATF below . I still believe a drain & fill schedule for ATF is in the best interest of the AT longest life ... Your thoughts ?
Just remember, MOST Hyundai's and Kias as of 2013 1/2 use a factory Group 5 Ester based ATF SP4-M, one of the only ones I know of. That is when they started to build their own transmissions and their engineers NOW had their name on then and they knew better and demanded a Group 5 ATF and the big wigs approved the use. So you have at least some extra time seeing you have a quality ATF right from the factory. If it is speced for SP4-M.
MaxLife is SP4-M compatible/comparable and a synth ATF:
http://content.valvoline.com/pdf/maxlife_atf.pdf
We are actually having issues at Honda/Acura with Maxlife, which is OE Honda fluid.
At first it was thought the vehicles had defective torque converters. We were updating software, then updating again, then replacing torque converters. Turns out, it is just the fluid breaking down faster than Honda thought. Now when we have a car with a torque converter shudder, we do 3 transmission flushes. This is on top of flushing it every 48k km.
I would not hold my breath thinking this fluid is "lifetime".
Quote:
On some 2013-2016 RDXs, 2012 RLs and 2012-2014 TLs, 2012-2013 MDXs, a judder from the torque
converter lock-up clutch may be felt while driving at speeds between 30-95 km/h and the problem is
typically diagnosed as a bad torque converter. Honda Canada investigated the judder and found that
the torque converters were not causing the judder; it was caused by deteriorated transmission fluid.
The transmission fluid deteriorates quicker than expected when it’s exposed to intermittent high heat
loads under specific driving conditions.
