Ivebeen using MMO for a while now, in winter, as an easy startup, for my 95 neon ATX SOHC> I always had a problem with ticking or clatter under the hood, upon a good cold startup, meaning the temeprature was about20 degrees or less, and sat outside for more than 8 huors...hard starting. Used MMo and alot easier, but still have alot of engine clatter..other day i used seafoam...i put 8 0zs. into 7 gallons of gas, and the ticking/caltter laste only about 3 minutes max, then smoothed out... it appeare to have done better than MMO...
Was wondering, what was everyone else's thoughts and experinces, with both products on cold morning starts with these products!
I have also used over and over, lucas gas additive, while it did give em a much easier startup, still had lots of chatter under the hood...seafoam seemd to diminish it to smooth idle in 3 minutes or less...
