I just used some Scott 1000 sheet in some submicronic bypass filters. I had been using Scottt Kimberly Clark and removing 10 rounds from it. I think the 1000 shet is a better roll. It is very tight wound. I removed 50 rounds from it to make it the perfect size. I figured out what to do with the 50 founds that I removed. I am very inovative
I used the 1 5/8" core, the 1 1/2" that has been showing up in the stores will also work. The 1 1/2" might have an advantage for fuel because it will seal not only at the bottom but 2" up the tube.
Ralph
Ralph
