Ford 2 valve 5.4What kind of engine?
So why did you pull the head off if the engine ran fine before? Have you heard of the saying, if it ain't broke don't fix it?Pulled the head off and found this in cylinder 1.
This engine ran fine before.
Even if it does, it's likely to be fine in that engine.If the score doesnt catch a fingernail its fine
Oh it definitely does. Both the ridge and the scratch. At least now I know where the piston slap is coming from.Even if it does, it's likely to be fine in that engine.
Can't tell from the pic. Can you feel the ridge, like get it caught by a fingernail? Also, what does the cross hatch look like? Drop the piston down (and vacuum that crud off!), I'm curious how much polishing is on the major thrust surface. To me, something these days with a big ridge ought to have nadda left for cross hatch, just seems like, none of the teardowns I've watched have ridges (clearly I'm no expert here).
One vertical scratch? Kinda deep for just one. If the others are fine... ring got hot and butted up on itself? hot in one cylinder, so it self-reamed (reamed itself a new one?) and now you have a weak cylinder? I can't imagine compression being great.
With that said, IIRC it needed a head gasket. I say, slap it back together and ship it. It matches the rest of the truck. Heck, do the compression test later, just for fun.
It was pumping a quart out of the head gasket every 70 miles. Was genuinely worried that it was going to catch on fire.So why did you pull the head off if the engine ran fine before? Have you heard of the saying, if it ain't broke don't fix it?
This looks more appealing every day. Not quite the price I'd like but I drive by it almost every day.Is this for the '01 F350? Rusted to death? The answer is obvious.
Any way to rotate the motor to see more of the bore? I’d guess not since you have the timing setup apart.
I’d be less concerned with that scoring (what’s visible in the photo) and more with the dulled finish on the bore as well as a ridge that’s not carbon. Can you catch it good with your nail? If you can, stick a snap gauge or dial bore gauge just to get a quick idea of how much it’s worn.
A compression test wouldn’t have been a bad idea before tear down.
I took it apart because it was hemorrhaging a quart of oil every 70 miles out of the head gasket. I've owned enough Jeep 2.5s and 4.0s to not fear piston slap. If it wasn't leaking oil, I wouldn't have touched it.You took it apart because there was a piston slap, right?
If it had piston slap, given what you just found, it’s time for a rebore and new pistons.
