As I recall, the VW Bug rear axel torque was 900 ft.lbs. Seems the Germans don't want it to come loose.
Smoky
Smoky
They are Whats called a TTY (Torque to Yield) bolt. It is a strange feeling on these because the torque is so high, at 148ft.lb it feels tight then at 90° it feels very tight but after that for the last 90° you can actually feel the bolt stretching.That spec completely baffles me. I can't believe the fastener would even stand up to that.
At almost 68 years old I need a little equalizer in the form of a 40" 3/4 breaker bar and that was bending slightly but it is doable."148 ft.lb then 180 degrees".
I'm sure I wouldn't even have the strength to do that.
Better get a 60" breaker bar now for when you are over 70.They are Whats called a TTY (Torque to Yield) bolt. It is a strange feeling on these because the torque is so high, at 148ft.lb it feels tight then at 90° it feels very tight but after that for the last 90° you can actually feel the bolt stretching.
Not on these, the hub bearing is right behind it as well as the CV axle. Where you would need the heat is a taper going into the CC nose, no way are you getting that hot enough with getting the sealed hub bearing smoking hot.Blow torch is your friend. Blow torch, followed by hair hammer with a nut buster attachment followed by blow torch again.
'Extra Gutentight' as the Germans would call it.That spec completely baffles me. I can't believe the fastener would even stand up to that.
Well that sucks. Welcome to snap town population 5 or 6 bolts and your sea of salty impotent rage tearst on these, the hub bearing is right behind it as well as the CV axle. Where you would need the heat is a taper going into the CC nose, no way are you getting that hot enough with getting the sealed hub bearing smoking hot.
Large diameter bolts on the German cars compared for the same placement on say a Honda. I don't get why the TtoY is even needed other then head bolts, mains and rods. I just don't see it needed in engine motor mounts, and control arms where the large diameter bolt is fine as a non Tto Y bolts.They are Whats called a TTY (Torque to Yield) bolt. It is a strange feeling on these because the torque is so high, at 148ft.lb it feels tight then at 90° it feels very tight but after that for the last 90° you can actually feel the bolt stretching.
