Changed the trans fluid in the Ranger last night. Has the M5OD and the RP has been in there for 31k. Put it in at 5k and now 36k.. maybe I should of flushed it with regular first? Shifting has been very notchy for sometime and likes to pop out of third gear (although I think that's my fault). Last winter it was like shifting a stick in mud. Came out like water quite a bit thinner than it came in (trans was cold) and the sludge on the magnetic was enough to make it twice it's original size. The only reason I put it in there is I figured it would hold up better than any Mercon flavor. And no it's never been flooded.
Put ST Mercon V with 2 ounces of Lubeguard Red back in. Just around the block a big difference. Thinking of running it 15k and changing it again. Starting to wonder what the rear diff looks like as it was changed at the same time.
