Originally Posted By: jk_636
Not only do most want Walmart oils and filters, but they all want to expect the cheapest oils and filters to last for unrealistic service intervals, then gripe incessantly when they inevitably fail. Some of the members of this forum are a different breed for sure...
At first I thought you were referring to M1 EP and Fram Ultra filters, both guaranteed for 15k miles and both superbly high quality leading edge products.
But then I remembered that I saw MMO and Tearolator's at Walmart which must be what you're referring to when you talk about cheap and failing.
MMO needs to go in each tank of gas and reduces your oil change by a couple of thousand miles, down to about 3000 miles.
Which works out great if you pair it with a Tearolator because that too is only good for 3000 miles!
