Is this the 3 speed automatic or a computer controlled 4 speed? Do your dash blend doors run on vacuum? Might have some sort of HVAC vacuum leak that's either affecting your MAP sensor or the transmission stuff. Might be able to trace its vacuum source and put a golf tee in it temporarily. AC should still work but will blow through the default blend door, usually Defrost.
