This Powerstop Z17 pad/rotor rear kit has less than 10k on it. Why the grooves on the rotor surface? Pics of both sides.
Less than 10 K was supposed to be. Changed. It’s had one winter. I’m semi retired so vehicle only gets about 8K a year. Yes parked outside. I try to keep it clean and I do spray salt away in the winterLess than 1,000 miles but how many months? Does this get parked outside?
Been a dry summer, but if that has some winter usage, then I'd blame it on rust.
Ah ok. To me that's normal. Splash on some of our salty water in winter, and it will get rust. Our cars get parked both in and outside, and I think indoors is worse, but they both suffer greatly. To me, it's just not surprising to need rotors every 5 years, although I have nothing against using records for rotors--it's just more braking surface.Less than 10 K was supposed to be. Changed. It’s had one winter. I’m semi retired so vehicle only gets about 8K a year. Yes parked outside. I try to keep it clean and I do spray salt away in the winter
So that means the grooves will even out as the pads wear down?Embedded metalic chunks in the pads create that pattern. Normal from my experience.
No. They will most likely stay grooved for the rest of the pad life.So that means the grooves will even out as the pads wear down?
Yea, OE Toyota is gentle on rotors but I’ve seen some aftermarket cause this.Pads cause this. I see similar effect running Brembo ceramic pads in the back but no issues at all with Bosch CQ in the front, both ends had new Bosch rotors installed along with pads.
