Originally Posted By: saaber1
What is the stratified fuel injection and how does that differ from the US models?
AFAIK, it's basically a way to shape the injector pulse so that the AFR is locally richer around the spark plug and leaner toward the edges of the combustion chamber. This is a way to have an overall AFR that is relatively very lean, with less risk of knock. It's not used on the American models for the reasons just discussed.
So far the widely touted (on this site anyway) method to deal with the the issue is to use biosyn oils. I have also heard the another option is to use a high HTHS oil. What do you think the best solution is for us models?
Again, AFAIK: High HTHS is good, because it's thicker and usually less volatile. Apparently RLI's stuff is even better because it has those benefits plus some other neat things about its chemistry that resist fuel dilution in other ways.
