- Joined
- Nov 29, 2009
- Messages
- 9,608
Can't you just throw a new gasket or even coat it with rtv and throw the pump back on? The mechanic told me the bearing gets water in it when the seal leaks. This been sitting on my shelf for like 5 years and I expected to not be able to even turn the pulley, but it seems fine. Unless it's supposed to easily turn a couple times with my hand. This is the one off my cummins. It runs off the belt on a separate area of the engine and isn't behind the fan like most are and only takes 10 minutes to change
