I have a 2012 Prius V and from all accounts-the equivalent of Toyota WS atf is recommended, which would be Redline D6, which I have in my transmission now. Curious that Redline also recommended this non slip CVT fluid for the car as a secondary recommendation. Checked with Dave and he confirmed it.
“The Prius has an e-CVT, i.e. an electrical CVT. The concept is the same as a classical mechanical CVT, in the sense that it gives a continuous variable transmission from engine to the wheels. However, the implementation is completely different. Instead of using a friction belt, it uses two electric motors and a differential gear.”
Was curious if the cvt fluid would be suitable for the vehicle… Redline’s recommendation was the first time I have seen the recommendation for cvt fluid as well as the standard low viscosity atf.
