Has anyone experienced lspi using Redline in turbocharged direct injection engines? Actual experiences. If so, I like to know.
That was my understanding tooI asked this in the past too and I have not heard of anyone that had LSPI issues with Red Line. The higher level of Moly, ZDP and ester base oil is apparently good at mitigating LSPI.
Have you heard of anyone that had LSPI with any oil?I asked this in the past too and I have not heard of anyone that had LSPI issues with Red Line. The higher level of Moly, ZDP and ester base oil is apparently good at mitigating LSPI.
the 2.0 Cadillac cts had plenty in the first couple of years of production,i believe it was the14 and 15 models.i saw one with busted piston.Have you heard of anyone that had LSPI with any oil?
Yep saw lots of pics of that carnage from dealer buddiesthe 2.0 Cadillac cts had plenty in the first couple of years of production,i believe it was the14 and 15 models.i saw one with busted piston.
still didn't understand how an oil can prevent a piston from cracking.
So if it was predominant in this particular brand and vehicle, does that indicate a material or design defect?Yep saw lots of pics of that carnage from dealer buddies
Oil is band aid. They key is design. European turbo engines, with few exceptions some 15 years ago, are not prone to LSPI.Has anyone experienced lspi using Redline in turbocharged direct injection engines? Actual experiences. If so, I like to know.
My 2009 MINI JCW Clubman (1.6l turbo) wasOil is band aid. They key is design. European turbo engines, with few exceptions some 15 years ago, are not prone to LSPI.
There was a podcast or something where Lubrizol engineers stated that a Dexos1 Gen1 oil was in use on a vehicle that had a catastrophic engine event involving LSPI. I believe this was in Las Vegas ...
Could be that that engine has an issue. Premium gas?My 2009 MINI JCW Clubman (1.6l turbo) was
throwing superknock codes a couple times
a month on random cylinders until I changed
to SN+ oil. Then it stopped happening.
No idea. Probably design....by using a small highly loaded engine, that sees alot of boost at low rpm. Not a great design in my opinion. Of the GM ones that I was aware a bit, most of the issue was in the heavier cars(caddy), as compared to say a cruze.So if it was predominant in this particular brand and vehicle, does that indicate a material or design defect?
There are numerous small turbo engines that do not have this issue. Europe is full of them. Yet, they do good.No idea. Probably design....by using a small highly loaded engine, that sees alot of boost at low rpm. Not a great design in my opinion. Of the GM ones that I was aware a bit, most of the issue was in the heavier cars(caddy), as compared to say a cruze.
Thats why I say design....some models issues, some dont. Are the euros as heavy as , say the caddys that were having issues? I would think some of these heavy cars are under boost most of the time by design, to make them "feel" like the v6 they are replacing.There are numerous small turbo engines that do not have this issue. Europe is full of them. Yet, they do good.
