Hi All,
When sold in Japan, this engine was fitted to the Nissan Stagea – a large station wagon aka estate with a 5 speed auto + 4wd weighing ~1700KG. The engine is a twin overhead cam, VVT V6 2.5L single turbo, 206 kW, running 13psi. The OE oil spec is the Nissan specific 7.5W-30 (like the RB series motors) with 10,000km OCI.
I recently bought a 93,000km Stagea and immediately changed the oil to Valvoline SynPower 5W-40 (mainly because of availability and price). I am thinking of trying a ?W-30 next time, but there's a lot of resistance to running a 30 on the Australian tech forum. Reasons given are “Australia is a lot warmer than Japan” “many engines are noisy on ?W-30s”. Here are some other quotes;
“I suspect the majority of the oil viscosity noise is coming from the VQ cam chain tensioners, the two smaller chains between the cams. These tensioners have restrictors in and out, and can bleed off too quick with a thinner oil, not pushing the chain with enough force to keep it tight. I find a 10w40 perfect to remedy these noisier engines. Any thicker simply makes the car feel lethargic”
“Neo 10w40 or Motul 300v when I had the VQ25det, changed every 10,000. Anything else and I'd dump it after 5,000.”
“5W30 was too thin and why would I bother getting it tested when it was quite obvious to me on a 50K old motor that never had a rattle before on 10W40 that it was wrong. Personally I think your crazy to run anything under a 10w40 in these unless you live in the snow.”
“I agree, every car I have heard with engine rattles has had the standard mechanic's 5w30 (Commo spec) oil. Just remember these VQ's run 90+ degree oil temps daily, even in winter, and I have seen over 10 bar oil pressure on my gauge.“
Comments please? Should I try, say, Mobil 1 5W-30 ESP and get a UOA at 5000kms?
