Radiator hose connection leaking
Toronto
Bottom radiator hose connection to radiator is leaking when the radiator fluid gets hot.
Saab 9-3 2.0T 2008
I purchased new hose and still the same problem.
I see there is a tiny nick on the pipe radiator on the front of the plastic radiator pipe connection, but I can't tell if it's a crack. Don't think it is.
I'm not sure if it's the pinch clamp itself that is weak or what.
Seems like a simple thing but no idea why it's still leaking.
Any ideas?
When it gets hot = under pressure... which is of course when its going to leak.
You might need to dig into it more and get a better look
otherwise:
@Trav might have some good suggestions.
If it’s a new hose and a properly applied clamp (and the neck was clean on installation) I’d be looking for a leak higher up that’s just draining down and dripping from the lower hose.
So I checked the old radiator, the "nick" that is there on the pipe connection that I thought was a crack, looks like it's just part of the mold / design as it's in the exact same spot.
otherwise:
It's definitely coming from that connection pipe.
I am sure this is NOT the case, but paranoid now that it COULD be.
I was doing some work to the car and had to disconnect the radiator hose.
I had inserted (just some cloth like material) capped off the pipe to prevent coolant leaking out.
But I am sure that I took it out before I reinstalled it.
Now, my question is, could a blockage cause that sort of leakage?
Engine temperature is normal after driving and the fluid does circulate through the system.
Is this a replacement radiator? Is the hose OE or aftermarket? What type of clamp is being used?
It's a pinch clamp.
Bottom pipe connection from radiator looks like this
So the area between that pipe hose connection just gets wet with coolant, doesn't even drip unless after a while.
Then after engine warm it leaks a lot under pressure.
I had a leaking hose on my Kawasaki motorcycle radiator hose. A new clamp didn't make any difference. So I went to my local Advance auto parts store to see if they had something to try. What I found was a was a repair kit that had 2 clamps, and a tube of rubber cement. At this point I had nothing to loose because anti freeze was leaking over the engine. Well It worked. It's been about a year now and it hasn't leaked a drop. Just my two devalued cents.,,,
Eventually I could try something like that but at the moment want to solve this problem.
It's a new hose and radiator connection seems to be fine.
Pinch clamp SEEMS to be fine.
I'm thinking two options:
1) the pinch clamp is the problem, could I use a regular hose clamp instead as a replacement?
2) I highly doubt it but maybe, there is some blockage, I would need to flush out the coolant system
Assuming the hose goes on the nipple with a normal amount of resistance, I'd butter up the interface with black RTV silicone and then clamp that mess shut.
Is there a chance that when you replaced that hose, you reversed it? Could the hose be 1-1/8" on one end and 1-1/4" on the other?
I went through the same thing on a old Nissan Frontier 6 cylinder. Mine turned out to be a pinhole in the aluminum hose fitting on the motor. The hose would cover the defect but it was not sealed by the clamp. I finally found it by removing the fitting and cleaning it up. Very hard to see.
