5487 lbs, so, yeah.I’d guess the Range Rover is going to be the driver on weight,
The QJ in post #3 maintaining a parallelogram shape (not an upright, stabilized rectangle) is unsettling to me.
LOL..You have 8 cars which you can measure the min-max yourself and you expect use to know which will fix?Based on the vehicles in my signature, which one will be best for all of them, and will I need to buy anything extra? Mainly concerned with them being to fit under the low sitting cars.
Curious to know where do you place the jack stands when the jack points are occupied by the QJ.My QJ works well and is stable.
I do not go under the car without 4 jack stands placed underneath the QJ.
6 ton stands extend to within .5” at the top height.
Not sure what wobbling you talking about. Rock solid!My QJ works well and is stable.
I didn’t mention wobbling.Not sure what wobbling you talking about. Rock solid!
@Pew said thatNot sure what wobbling you talking about. Rock solid!
The jack stands go under the platform in the event the QJ fails.Curious to know where do you place the jack stands when the jack points are occupied by the QJ.
Yeah, quoted the wrong post.@Pew said that
@Pew said that
What do you need an air compressor for? The hydraulic compressor comes with it.Indeed. Although it was a friend's QJ and I've never used one since so maybe it was just his specifically? Probably didn't help that we were trying to get the motor and trans out.
I'd still want one, although I don't have an air compressor. I don't think there's a single person on this forum that has one and has anything bad to say about their QJ.
When it comes to wobbling, was the surface flat? Also, what is super, uber important is to push any air out from hydraulic lines so both sides rais the same.
They are too heavy to do simple stuff like oil changes (I use ramps). I would not recommend it to someone that does not work on suspension etc.
Comes with a hydraulic compressor, and you buy ATF. Takes 1.5qt, something like that. Purging air is the most important thing.Oh, I didn't realize that, I saw my friend's was hooked up to something but I didn't bother checking so I assumed they hooked up to something that I didn't have.
It’s stable. It’s strong. I had a Mercedes on one for nearly a year. No worries.The QJ in post #3 maintaining a parallelogram shape (not an upright, stabilized rectangle) is unsettling to me.
