Originally Posted By: The Critic
Originally Posted By: Jim Allen
If you install oil better than the calibration oil then you have some built in leeway. If you install lesser oil, you go in the opposite direction.
Depending on the specific circumstances, all oils will be the same. All oils will pick up contaminants (blow-by and fuel dilution) at the same rate. Also, all oils likely contain about the same amount of anti-wear additive as well, due to the API and ILSAC regulations. Therefore, the only real differences between most synthetic oils and conventional oils are the slight improvement in oxidation resistance with synthetic and the added detergency in certain brands, which may or may not be useful. Therefore, based on those assumptions, oil life is going to be the same.
I think you may be minimizing the differences in oxidation resistance but there are so many aspects that muddy the waters, you are probably correct in most cases. The only way to know would be to run some significant tests. Another point that I didn't consider is that, from what I see, GM is using some pretty decent oils for FF these days, thus narrowing any possible gaps.
