For those who "think" their method is correct, be it crimping, soldering, or combined, you should google the subject and execise your OCD. Aviation, boating, and car enthusiasts argue the crimp vs. solder methodology ad-nauseum.
If memory serves, soldered connections are forbidden in aviation and the boat building industry "standard" also recommends the use of crimps only. Someone correct me if I am wrong. These are two harsh environments that "favor" crimps only.
Here is an excerpt from one site:
http://www.virginiawind.com/tips/060801_02.asp
"Most crimp terminals are designed to be crimped, not soldered. If the crimp was done poorly, solder won't save it. And if the crimp was done properly, solder is unnecessary. In fact, soldering a crimped terminal may weaken the mechanical connection, may reduce electrical conductivity, and may damage the terminal. As a general rule, you should not solder a crimp terminal."
"In the final analysis, a soldered connection is neither inherently better nor inherently worse than a solderless connection. Each has its advantages and disadvantages, and each may be appropriate or inappropriate for a given application.
The key to a successful electrical connection is to remember that, if you choose to solder, you must be able to solder properly, and if you choose to crimp, you must use the proper tool and select a solderless terminal that is suited both for crimping and for its intended use."
I"ll let you guys study why poorly soldered connections can be as bad as a mediocre made crimp. It's a fascinating debate, IMO. Nearly all of my crimping is on indoor building work that is less demanding.
Cheers.
