Here's an analogy. If you stand in a dry river bed, and then a wall of water comes flowing down the river bed and impacts your legs (and continues to flow a steady steam of water volume over your legs), the force your legs feel is the same from the second that wall of water hits you, and is the same force as long as you stand in the constantly flowing stream of water.
The water doesn't saturate my legs.
Doesn't matter. Go instrument your legs with force transducers and go do the river bed test.
Failed analogy. Besides my legs not becoming saturated, there is another key difference: 100% of the water goes AROUND my legs, whereas 100% of the oil goes THROUGH the media.
If your legs were made out of filter media the analogy would still hold true.
If you think it's a "failed analogy", then please show/explain why you think in-rushing oil volume (that never changes in volumetric flow during this scenario) puts more force on the media when it first hits vs. after it has filled the oil filter.
The force (delta-p) on the media is only a function of the oil viscosity and GPM flow rate, and those factors don't change at any time between when the oil first hits vs time after it hits the media.
