Originally Posted By: Colt45ws
Originally Posted By: Fordai
If the ADBV is up towards the engine then a cut ADBV doesn't really matter right? No oil will escape the filter UP into the engine because of gravity.
Correct. But, are you gonna pay for $12 for shoddy workmanship?
Gents - In a base up or almost base up application, the ADBV should keep oil in the galleries above and below the filter. When the ADBV leaks in this configuration, oil should remain in the filter but the galleries could easily empty. This sets the stage for a dry start.
In a horizontal application, when the ADBV fails to seal, the oil can easily drain out of the galleries and the filter. This sets the stage for a longer dry start than base up configuration.
When the filter and galleries are kept full of oil, then startup lubrication is maintained and thus wear is minimized during this period.
If you notice startup rattle, then a leaky ADBV may be the cause. If you don't notice startup rattle, then your application might not need an ADBV.
You are right, I would not spend $12 for a filter that did not maintain all of it's functionality through the marketing speak recommendation which is 15,000 miles for this filter.
