I was checking fuses at random (dumb, I know). Anyway, my son was in the driver's seat and had his foot on the brake. When I pulled the ABS fuse, the brake pedal went to the floor per his report. I did hear a clicking around the master cylinder when I pulled it. I put the fuse back, but now he has soft brakes to the point of the car not being safe to drive. ABS light goes off as usual upon start up.
Did we blow a seal? I tried bleeding the Master Cylinder/ABS system as they are integrated per Haynes manual instructions. No fluid comes out of the rear of the two bleeder valves, weird (which you are to do first). The forward bleeder worked as I would expect with my son working the pedal, but there always seemed to be air in it and the pedal did not firm up despite his desperate hopes. I don't know if bleeding the entire system will help or not.
Any ideas?
Any ideas?
