Quote:
has a leaking return line reaplced it was fast and easy then instantly a whine
I am almost 100% sure there is air in there, I've seen this before on this engine.
GM has a bleed procedure but even after doing this i had to pump the system under vacuum overnight to rid it of air.
this was a 3400 in a Venture van.
GM’s Recommended Bleeding Procedure:
1) Ignition switch off.
2) Turn steering wheel full left.
3) Fill fluid reservoir to Full Cold level. Leave
cap off.
4) Raise front wheels off ground.
5) With assistant checking fluid level and
condition, turn steering wheel lock to lock
at least 20 times. Engine remains off.
a) On systems with long return lines or
fluid coolers, turn steering wheel lock
to lock at least 40 times.
b) Trapped air may cause fluid to
overflow. Thoroughly clean any
spilled fluid to allow for leak check.
c) Keep fluid level at Full Cold.
6) While turning wheel, check fluid
constantly.
a) No bubbles are allowed.
b) If bubbles appear, recheck connections.
Repeat step 5.
7) Start engine. With engine idling, maintain
fluid level. Reinstall cap.
8) Return wheels to center position. Lower
front wheels to ground.
9) Keep engine running for two minutes.
10) Turn steering wheel in both directions.
