Proof Chevy V8's beat blown 4-cylinders - Focus RS
Originally Posted By: Olas
Doing it by software implies uploading a new file through the obd port. The laptop used would be filling in all the load cells to optimise for the hardware. How else you'd you program an ECU?
That's still using software. Depending on the tuning device and how tunes are applied you can save multiple tunes, tunes made using real time software on the laptop, and then switch between them without the laptop after the fact. I think you are trying to draw separation between "boxed" tunes sold on tuning devices and those done on the vehicle itself?
I have documentation (as do many others) that fitting non-factory parts voids warranty claims relating to the system that said parts were fitted to.
You didn't realise that there was no direct comparison, only that whatever comes from the factory can be improved upon.
I'd like to see the documentation. The reason I say that is that there's a big difference between replacing a factory Turbo for example on a vehicle with a higher output aftermarket model and that would rightfully void the warranty on the engine if it was able to be proven to be the cause of failure. On the other hand, there's no requirement to use factory brake rotors and/or pads and the most they could be tied to would be caliper failure which, if the aftermarket parts were significantly different from stock, MIGHT be a warranty contention issue.
(sorry, not sure how to break down quotes in the manner shown above)
No problem, you'll see the tags when you quote a post. You can shuffle the tags around and copy them to quote/unquote specific blocks of text.
So after transatlantic semantics, is it fair to say that you prefer what the OEM does as compared to what the aftermarket does?
It depends on the car. For a high performance variant that is kept mechanically stock I see no compelling reason to deviate from the factory tune for example, particularly when under warranty. On the other hand a vehicle that is not being kept mechanically stock and is going to be producing more power than stock, then a tune or tuning device may become a necessity. I have a buddy that used to tune for Steeda that had an '04 Cobra, significantly modified, with twin turbo's. Obviously that car was not under warranty any longer and required significant tuning due to the massive change in induction and power output (roughly 850RWHP on 94 octane IIRC).
On the other hand I see folks pulling off their factory induction systems and installing chromed tubes and rock catcher filters that are getting hot engine bay air thinking they are improving over what the OEM provided. This is a case where the OEM parts selection was superior but somebody thought an aftermarket part was "better".
For high performance models this is even more ridiculous as usually their induction systems are even more overkill (not always, but often). The twin filter intake setup on my M5 was the furthest thing from restrictive.
I feel like the factory car is a part finished job, and in "finishing" the job my car has shorter stopping distance, approx. 30% more power and higher cornering speeds - wether with factory parts or aftermarket parts you can always get more out of any car. Look at long tube headers and Hotchkiss suspension for example...
More at the expense of what though? Remember, the factory setup is designed to appeal to a broad audience so particularly with a car that isn't geared toward being driven on a race track, the handling is going to be a compromise that leans toward ride quality. When you start looking at higher performance cars, this becomes far less of an issue. BMW's M-cars, Mercedes AMG....etc. You don't get anywhere NEAR the improvement on these by buggering with the suspension as you do on a more mainstream vehicle.
So it isn't a matter of being a part finished job but rather a setup that's designed to appeal to a wide range of people and provide a satisfactory balance of characteristics that pleases them. In that vein, that's why they don't come with carbon/ceramic brakes either. It isn't that the factory simply left them out in hopes that an end user would do it but rather for the market the car is geared at, they aren't necessary nor would they probably be desirable. This same process is why the SRT cars come with much larger Brembo brakes whilst the regular LX cars come with "normal" brakes that will be much less expensive come pad/rotor time and provide adequate stopping for the anticipated operating conditions presented by your average driver.
Originally Posted By: lubricatosaurus
Olas is talking about updating the firmware, not the software, overkill.
Your usual weird over-reaction. Get a clue before calling Olas dumb with the
junk.
The engine computer's software lines of code run algorithms, and get lookup table values from firmware with the numbers.
Bottom line is it's possible to change constants in the firmware without over-stressing engine limits. Sure we engineers can get over confident in our abilities to know where the limits are, yet being clueless about vehicle physics like overhill is the naive extreme.
Have you ever tuned a car? How about YOU get a clue and stop with the personal attacks. Notice how Olas didn't come back at me like I was offending him? Naw, you had to do it because you have a hate hard-on for me. That's OK though, I find it flattering that you dislike me enough to follow me around wasting your time like you do.
And he's not talking about updating the firmware, he's talking about modifying the tables used by the ECM (which runs the firmware) in real-time versus using a canned tune, which is not vehicle specific and far less precise than using tuning software run on a laptop.
The Firmware is what RUNS the car; it is the operating system (or systems) of the vehicle. It/they use the data programmed into the various base tables along with the adaptive strategies to write the long term and short term tables.
I've done real-time tuning with a laptop connected to a tuning device that allows both canned tunes and generated/saved tunes. We used a wideband (the car only had factory narrow band sensors). This was in an '88 Mustang with aftermarket heads/cam/intake + other mods making more than 100HP more than stock. What's your experience?
An excellent extension of this, applicable to all vehicles, is the offering of a number of "race spec" or "track spec" brake pads for many street car applications now. You can fit track brake pads to any pedestrian Fusion or Camry now. Are they an improvement over OEM? It obviously depends entirely on the use and the driver. In certain circumstances, they may offer an advantage. But, that's likely at a level to which most drivers will never take those cars.
To me, it's the general concept of "more" isn't always "better", "better" isn't always "more", etc. It always depends on the use case and the various factors involved. Just as Corvettes and Vipers aren't right for everyone, so, too, long tube headers and race brake pads aren't for everyone.
For a single cold emergency stop, the brake system isn't really a factor anyways, the grip level of the tires are far more important.
For perfromance driving, then everything has to be up to snuff though. The generic cheapie pads that were on my Neon would fade shockingly fast on the 3rd stop from 60 mph... A set of performance pads cured that but then they needed some extra pressure for maximum braking until they warmed up, which would be unacceptable for an OEM setup.
They worked well for relatively slow trackdays though, which is pretty impressive for tiny disc brakes that fit into 13" rims.
I think one thing we need to keep in mind with regards to a turbo-4's durability is duty cycle.
That peak power will be seen on a very infrequent basis, mostly limited by physical space. If one attempts to apply 100% of the power 100% of the time, how long will they be able to sustain until they run out of road or are arrested by the police?
That factor alone will likely keep engine durability pretty close to stock.
Dont flatter yourself. You're in my thread, insulting people with that bizarre attitude of yours. Go bother some people with IT stuff, not here where cars are discussed, obviously not your forte.
Or you can go read specs off oil bottles and report your readings, what you usually get right at least.
You really don't understand this stuff, do ya? It shows.
Wow, just wow, you're beyond arrogant and way off. Bad combination of
for you.
Firmware doesn't "RUN" the car. Totally wrong. Tables in memory establish constant parameters, limits, coefficients, etc. for linear and non-linear control and logic algorithms to create control loops and feed-forward commands.
And, its not the "operating system", total misuse of that technical term. (Are you really even an IT tech?) Operating systems schedule thread tasks and manage utility low-level functions completely underneath the algorithmic embedded software, and completely separate from stored numbers in firmware.
But please continue to write an encyclopedia of insults and strange whining, like you usually do.
Originally Posted By: DoubleWasp
Porsche did the performance 3.0 4-banger 20 years ago with the 968. Can be done.
That is interesting. News to me. It was a oversquare and multivalve, and the Porsche actually had a slightly larger bore diameter than our hypothetical half-LT1 3.1L I-4.
Further research, noticing International Harvester 40 years ago chopped their 6.4L pushrod V8 in half and made a 3.2L slant-4 and put it in their Scouts. With that, and GM's Iron Duke being half a pushrod Pontiac 5.0L V8, there is plenty of precedent.
Looks like GM should put a half-LT1 in their Colorado/Canyon pickup trucks at least. Cheaper heads and valves for sure. ... New concepts in the use of electric motors in series, using pulsed-torque to fill in the 4-cylinders torque valleys, would smooth it out quite a bit and make it a mild hybrid too. Fake acoustics synched to the missing I-4's power strokes (compared to the V8) would return the V8 sound too!
Keep it up with the insults, I wasn't insulting Olas, the only one tossing out the insults is you.
More insults, what an incredible display of that wonderful character of yours.
Yes, because you deal with software, you a programmer too now?
Sounds familiar....
Bad combination of
for you.
Might as well just point you to the Wiki:
https://en.wikipedia.org/wiki/Firmware
Originally Posted By: Wikipedia
In electronic systems and computing, firmware[a] is a type of software that provides control, monitoring and data manipulation of engineered products and systems. Typical examples of devices containing firmware are embedded systems (such as traffic lights, consumer appliances, and digital watches), computers, computer peripherals, mobile phones, and digital cameras. The firmware contained in these devices provides the low-level control program for the device. As of 2013, most firmware can be updated.[2]
Firmware is held in non-volatile memory devices such as ROM, EPROM, or flash memory. Changing the firmware of a device may rarely or never be done during its economic lifetime; some firmware memory devices are permanently installed and cannot be changed after manufacture. Common reasons for updating firmware include fixing bugs or adding features to the device. This may require ROM integrated circuits to be physically replaced, or flash memory to be reprogrammed through a special procedure.[3] Firmware such as the ROM BIOS of a personal computer may contain only elementary basic functions of a device and may only provide services to higher-level software. Firmware such as the program of an embedded system may be the only program that will run on the system and provide all of its functions.
Quote:
As originally used, firmware contrasted with hardware (the CPU itself) and software (normal instructions executing on a CPU). It was not composed of CPU machine instructions, but of lower-level microcode involved in the implementation of machine instructions. It existed on the boundary between hardware and software; thus the name "firmware". Over time, popular usage extended the word "firmware" to denote anything ROM-resident, including processor machine instructions for BIOS, bootstrap loaders, or specialized applications.
A simplified example from the IT field:
A router has firmware that runs it. This is the operating system, in many cases this is now the Open Source product Linux. It also has configuration files that are user modifiable and system modifiable, these are not part of the firmware, they are simply accessed/modified by it. Similar to the MAF tables, load tables, spark tables....etc that one manipulates using software on a laptop when tuning a car.
I dont think its hard to see basically a rally car isn't going to be tuned for MPG.
Why would you buy a focus RS for mpg.. they have that 1-liter ecoboost 3 cyl for that?
2 totally different cars.. next up you will tell us go buy a f150 raptor its better than a focus rs..
2 totally different vehicles aimed at different markets.
So far I'd rate this as overkill-2 Lubrotrollasaurus-0
I also find it hard to take seriously someone with a name of lubrosaurus and what exactly is dank art engineering? You design weed greenhouses?
Not done by software, done live on a laptop and rolling road.
And what runs on a laptop big guy? Software!!! Good grief
junk.
Thanks bud
It seems like we all agree that more is available regardless of what you buy, some people get a sense of satisfaction from knowing they improvd their brakes, or their torque curve, others are happy to drive around in whatever the factory churned out.
Thanks. That was the point I intended to make without actually making it!!
High performance parts can sometimes perform worse than factory-spec stuff at the duty cycles commonly seen on the street. Whether that's brake pads or camshafts or anything else. More than anything, the compromises established by the performance part have to be matched to the application. You can't stick a fat cam in an engine and still hope it idles like stock, or even pulls like stock off the line. You can't put track pads on it and hope it still stops well on the first few stops out of the neighborhood in the morning.
GM also did the half-of-a-V8 on the original Pontiac Tempest I4, which was half of a 389. It didn't last many years in production because it vibrated horribly.
I don't think the Iron Duke was based on Pontiac's V8. I think it was a resurrection of the Chevy II 153 I4 of the early 60's. GM sure built a lot of Iron Dukes, but it never got much love as something to modify for greater performance in a street car.
Do GM do an Astra equivalent in NA? The new one has 280hp and 290lbs/ft from a 2.0 at about 1400kg depending on trim etc..
The U.S. got an Astra for one model year, 2008, from the now extinct Saturn brand of GM. That GM Opel Astra platform was hot for a while, being here the summer of 2008 when oil speculators and supply disruptions drove the price of gas high, so people bought a lot of them even though the car had very little power at the time.
That 3100 lbs is light for 280 hp. Should be a hoot to drive in Europe.
GM doesn't compete with the Ford RS or Mitsu EVO categories in the U.S. anymore. Chevy Cruze (Delta Platform GM) here only has weak engines, so nothing to compete with hot small cars from Ford, Honda, Mazda, Mitsubishi, Subaru, etc.
GM NEVER had a 'rally type', AWD and turbo I4 small car, here OR in Europe (the closest they came was the Group A Calibra for one or two years).
The Sonic would make a great little rally car with a 2 liter Ecotec turbo, and a good AWD system, 4 wheel independent suspension, and 6 speed gearbox set up.
Drive both of these cars with the a/c on then tell me which one you want.
You should see another contender soon in the hot-hatch segment with the return of the Mazdaspeed3.
I think the cost and rarity of the Focus RS will make it a bad buy compared to the camaro or mustang V8 offerings. People pay over sticker for Golf R all the time. I think the V8 will put up with a lot more abuse than a highly boosted 4 cyl.
I'd still love to have an RS, but the economist in me would force a highly discounted american muscle choice.
Also used in many boats as a 3.0 liter 4 banger. Very torquey and simple...
The biggest 4 cyl I've driven is the 2.8L 4 cyl turbo diesel in a 06 Liberty, and I found it pretty smooth really as far as vibrations.
Is a LT1 an expensive engine to make really? It seems it should be cheaper than their 3.6 V6, just based on the number of precision parts, lower hp/L.
Sadly, my parent's red, rag top, '63 Le mans with that engine (auto) caught fire on the N.J. Turnpike (with 12 year old me and my mom in it!), and burned to a total loss.
I noticed flame and smoke coming through the console/shifter slot, and told her to stop NOW, and GET OUT!
It might have still been around if my dad had opted for the 326 instead (he was afraid to get the V-8 since my mom had what he referred to as a'lead foot').
