I have used Pennzoil off & on over many years in older cars mostly. One of those vehicles presented a DEFINITE problem with Pennzoil. It was a '76 Dodge with 318 engine. On a cold start it had a SEVERE valve train noise until completely warmed up & then it quieted down. Changed to a different brand of oil in the same grade & the problem immediately went away. After that I never used Pennzoil again. Now I have a Buick LaCrosse,'05 with a 3800 engine & I had been getting it serviced at the Buick dealer,assuming they were using GM(Goodwrench?)oil. Wrong! Found out they are putting Pennzoil in it. It has a slight noise on startup that seems to be valve train,but quiets down after running a bit. When I first got the car,it was serviced at a different dealer(Ford dealer where I had worked before I retired) & they always used Motorcraft oil & there was no noise. The other cars I had used Pennzoil in were all earlier models than the '76 Dodge. Any ideas as to what's going on here? By the way,the car has 107000 miles on it,but runs like new. I presume the Buick dealer is using the Pennzoil because of price,but I don't need any more problems if I can help it. Owned a '02 Park Avenue previously,3800 engine,but used the Motorcraft oil & never a problem with it at 160000 miles. Hope someone has some ideas.............Jim
