Looks quite good, thank you foe posting. I've used plenty of these filters in the past along with the purolator 10241 on the Mazda3 previously in my signature. Along with lots of PROLINE, PEAK & SUPERTECH oils.
Looking back, this is the second PepBoys PPL 10241 you've posted that looks quite good. Last one was run ~8k, was ok too. For jobber tier filter, very respectable. And adbv baseplate design that shows no indentations/cuts. Appears central part adbv narrow enough, no compression spring pressure directly on inlet holes. They should use the same design for other applications. Thanks for c&p.
